Fuel Injector Ticking?
Old Mar 30, 2005 | 01:40 PM
cal camara's Avatar
cal camara
Default Fuel Injector Ticking?
I installed bosh injectors in my 1990 and they work fine. I however have a ticking that seems to come from the area of the injectors. Using a mechanics stethescope the ticking is evident at all injectors as well as around the fuel rails. The ticking sounds similar to a lifter but a little more tinny. The sounld does not appear to come from the valve trail. You can hear the ticking from inside the car with the window open. Any Ideas? Has anyone had an injector tick loudly?
cal
Old Mar 30, 2005 | 01:41 PM
vader86's Avatar
vader86
They all tick loudly, its normal.
Old Mar 30, 2005 | 02:00 PM
Steel Blue 91's Avatar
Steel Blue 91
Can't speak for the Bosh injectors, by my stock ones are rather noisey.
Old Mar 30, 2005 | 06:00 PM
vettish 91's Avatar
vettish 91
Just replaced my injectors a couple of weeks ago on my 91 with bosch injectors, your right , they are a hell of alot more noisy than the originals. The guy where I bought mine from at five-o-motor sports said this is normal.
Old Mar 30, 2005 | 06:18 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Once had an exhaust leak on my Jeep Cherokee. There was a crack in the exhaust manifold. It made a sound similar to a noisy lifter. (Welding the manifold cured the problem).
When I bought my Corvette, I heard the same sound when the windows are down. Took it to a muffler shop and asked them to check for a manifold leak. They said it was the injectors. (I didn't believe them).
Took it to another muffler shop and to a dealership, they said it was the injectors too.
I guess Corvettes have some noisy injectors....
gp
Old Mar 30, 2005 | 06:32 PM
music_man's Avatar
music_man
From: Cicero, IN "Change is inevitable, except from vending machines"
I have Accels in my 90 and they tick, but not real bad.
Old Mar 30, 2005 | 06:36 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default I was thinking.....
I was thinking of getting mine from 5 O also....but now Iam a bit weary....I don't mind how mine are right now....and they do tick a little loud.....but I really don't want them getting any louder....how loud over stock are we talking? One guy posted said a hell of a lot louder....hmmmmmmmmmmmm
Old Mar 30, 2005 | 06:46 PM
vettish 91's Avatar
vettish 91
Yeah, they are alot louder. To the point where I thought something was wrong after replacing them. Although anly 3 of my original injectors were working. So there was virtually no ticking before.
Old Mar 30, 2005 | 06:50 PM
XtremeVette
Default wow....only 3 working!!!
how the hell did your car even run! damn......
by the way vettish91, I sent you a private message.
Old Mar 30, 2005 | 10:32 PM
cv67's Avatar
cv67
St. Jude Donor '05
Replaced mine with Bosch's..I must say they are very loud but pleased with the way they work.
To Fuel Injector Ticking?
