Total Timing?
Old Mar 31, 2005 | 06:39 PM
91superram's Avatar
91superram
Default Total Timing?
What should the total timing be on a l98 small block for peek performance.I'm reading 36 @ 3000 RPM is this about right
Old Mar 31, 2005 | 07:04 PM
MrNuke's Avatar
MrNuke
Comes on what year engine / condition.
My stock '85 with stock 9:1-9.5:1 compression heads flew at 48degrees total, now I can only get away with about 41-42. (New heads)
Old Mar 31, 2005 | 08:01 PM
CFI-EFI's Avatar
CFI-EFI
How are you checking this? With the ECM controlling the centrifugal and vacuum advance curves, there is virtually no way to check this with a timing light, as you cannot duplicate WOT conditions in the driveway. If you are using a scanner, 36*, all in by 3000 rpms, at WOT, is right about where you want to be.
RACE ON!!!
To Total Timing?
