overheating problem!
Old Mar 31, 2005 | 07:31 PM
1badtrain's Avatar
1badtrain
Default overheating problem!
My 93 has been running hot when ac is on or i am driving with a semi-heavy foot. thermostat was just changed about 2000 miles ago, but water pump and radiator have never been changed in 140000 miles any thoughts on what it may be?
Old Mar 31, 2005 | 07:34 PM
rws.1's Avatar
rws.1
Have you cleaned out the space between the rad and the condenser?
C4 are notorious for collecting road debris in this space greatly limiting air flow thru the rad.... If you haven't checked that out.... it's your first step.
The next step is a rad power flush
Old Mar 31, 2005 | 07:38 PM
1badtrain's Avatar
1badtrain
Thanks i will start with those suggestions!
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Radiator should be removed ( and itself cleaned ) to do this cleaning completely. There is really no other way to get the trash out and trust us, if it has never been done, there is trash in there
seeya
To overheating problem!
