'94 Parking Brake Adjust??
Old Apr 1, 2005 | 03:06 PM
Donne Trav's Avatar
Donne Trav
Default '94 Parking Brake Adjust??
I think I need to adjust my PARKING BRAKE. How is this done on the 1994
—6 speed? THANKS
Old Jun 2, 2005 | 12:35 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Same as on the auto mate...
Old Jun 2, 2005 | 12:39 AM
Casethecorvetteman
or do you
acctually need the procedure??
Old Jun 2, 2005 | 01:32 AM
Red Dwarf's Avatar
Red Dwarf
—6 speed? THANKS
Manual says to pull parking brake up firmly 3 times..................
Old Jun 2, 2005 | 05:12 AM
Casethecorvetteman
No it does not... It says pump the brake pedal 3 times to make sure the clearance of the rear pad to disc surface is enough when the park brake is OFF. You should put new rear pads on before you adjust it too.
Old Jun 2, 2005 | 10:41 AM
Red Dwarf's Avatar
Red Dwarf
Not according to the Helm"s. Book 1 Section 5F-1.
Old Jun 2, 2005 | 12:06 PM
Casethecorvetteman
Does it say to pull the park brake lever up firmly three times in the Helms manual?? Cause i just tried that on my slack park brake on my 94, and it didnt change a thing. holds car on flat ground, but slowly moves on a hill.
Old Jun 2, 2005 | 05:15 PM
Red Dwarf's Avatar
Red Dwarf
Sure does. If that doesn't do it then you have some other issues. If you need any info from the Helm's let me know.
Old Jun 3, 2005 | 05:21 AM
Casethecorvetteman
so you swear by the Helms manual?? Honestly never heard of it until i got on here. What kind of price is that book? USD will do, i can do the AU conversion...
Old Jun 3, 2005 | 05:46 AM
Steel Blue 91's Avatar
Steel Blue 91
eBay has them or go to:
http://www.helminc.com/helm/homepage.asp?r=
Old Jun 5, 2005 | 05:17 PM
qwiketz's Avatar
qwiketz
I have a 92. Is the procedure the same?
My parking brake wasn't used in hundred of times using the car. Now I'm trying to get it calibrated again. When I first started trying what you mentioned above, it wouldn't even click. After about 6 or8 times, it would click once, twice or three times at the top of the pull. Now I have it to click about 6 or 7 times when you pull it. The brake light still isn't coming on. Should I just keep doing what I'm doing until it comes on? I would say that you have to pull the handle half way or three quarters of the way up before it starts clicking to engage.
Old Jun 5, 2005 | 05:19 PM
qwiketz's Avatar
qwiketz
Default Do I need a higher stall/idle speed with the hot cam setup?
anyone? I have a stock converter in there now. Car idles at about 600-700 rpm with it in drive.
Old Jun 5, 2005 | 09:17 PM
Red Dwarf's Avatar
Red Dwarf
Might as well keep trying.
To '94 Parking Brake Adjust??
