hey guys, quick question, I'm putting a new front bearing on my 84. As you know its all one assembly. Is there any special tools or tips that I need to know before i start?
thanks
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
thanks
Front bearings are pretty simple, at least they were on my 88
Remove caliper and roter, take out the hold down bolt on the ABS sensor, pull the sensor
There are 4 bolts holding the bearing assembly in, remove, replace and repeat above
