ground wire on the trans bolt??
Old Apr 1, 2005 | 11:45 PM
U_Dont_know's Avatar
U_Dont_know
Default ground wire on the trans bolt??
hey guys,
what is the ground wire thats on the top trans bolt, whats it for ?
thanks
Old Apr 2, 2005 | 12:41 AM
jfb's Avatar
jfb
I looked through my 87 electrical service manual which shows the location of the chassis grounds and was not able to determine what device that ground wire is for. You can follow the wire and determine what device it is ground for.
Old Apr 2, 2005 | 01:54 AM
DANSURE1's Avatar
DANSURE1
Default Ground wire
Could be batterynegative, Ground strap,you have 2 or 3 ground studs on your car motor, with more then one wire, Just keep them all clean. BRAKE CLEANER IS GOOD.
Old Apr 2, 2005 | 12:26 PM
RED95CONVLUVER's Avatar
RED95CONVLUVER
on my 95 that ground strap is for the FX3 ride control..
Old Apr 2, 2005 | 02:33 PM
bogus's Avatar
bogus
there are any number of grounds on the 87s.
One goes to the block, a couple, to the back of the right head.
The one to the block is the main neg battery post ground.
The ones on the head? I am not sure what exactly they do... They do come from the harness, tho.
Old Apr 2, 2005 | 06:58 PM
rick lambert's Avatar
rick lambert
Helps to post the year-because some had grounds for the same application in different locations.
Old Apr 2, 2005 | 08:22 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Doesn't really matter what they're for unless you're chasing a certain problem. On my '95 there were 4 or 5 on one tranny bolt which made things even more of a PITA to unbolt the engine along with the stock cat brackets, which no longer exist. I relocated all of those grounds upon reassembly, some to the back of the left head and others to an unused threaded hole on the left side of the block. Just make sure they're all clean and making good contact and have no excessive resistance.
Old Apr 3, 2005 | 05:00 PM
Mo_Bandy's Avatar
Mo_Bandy
Good Idea Corvette Kid NC,
My trans will be back from the rebuilder on monday...
I was thinking the same thing, it maybe easy for asembly lines but a real pain to get to once the car ins on the ground with the trans back in it...
Mine is a 96 and I know has the battery ground and about 3 -4 others I'm guessing from the ECM engine etc. etc.
Mo
Old Apr 3, 2005 | 07:39 PM
jtferris's Avatar
jtferris
Cruising
Default Bad ground cable?
I'm having a problem on my 84 where my battery is draining overnight. I put in a known good battery and measured for voltage drop and founmd I had 12.48 volts measured from the negative battery post to the negative main ground cable!
I checked all my fuses while looking at the voltage but it never dropped so I suspect maybe a bad gound cable???
Any advice appreciated.
Old Apr 3, 2005 | 07:49 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
...the strap was part of the circuit for my widshield wipers on my 89, ask me how I know
Old Apr 3, 2005 | 08:10 PM
Corvette Kid
Mo
Yeah it's been a while and I know I had to replace a terminal or two and extend some of them to get them where I wanted them but if there's any future issues with them, they'll be easier to deal with.
To ground wire on the trans bolt??
