Clutch Fluid ?
Old Apr 2, 2005 | 09:19 PM
Rane LT4's Avatar
Rane LT4
Default Clutch Fluid ?
I have a 96 LT-4 with 78k and the ZF tranny. Every now and then I have to top off the clutch fluid. There is never any puddles under the car and nothing under the hood that shows leaking. Is this normal to add some sometimes? I filled it up the other day and drove it about three times averaging about 50 miles per trip. I checked it today and it was back at the "add" line. Any ideas...Thanks
Old Apr 2, 2005 | 09:58 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Your clutch slave or master or both are going out. I'd look at replacing one or both before you forget to top off the fluid and suck in some air and start destroying your syncrhos.
Their life span is usually about the same, and they're not going to get any better.
Old Apr 2, 2005 | 10:19 PM
Rane LT4's Avatar
Rane LT4
Thanks for the reply. Can you tell me how much Im looking to spend through my chevy dealership to fix this. And also is this a major problem.
Old Apr 2, 2005 | 10:41 PM
pwoolford's Avatar
pwoolford
St. Jude Donor '08
I just installed mine and there is not much to it. The master and slave cylinders are around $75 each. If you have it done I can't imagine it taking more than a couple hours labor.
Old Apr 3, 2005 | 04:36 AM
2blklt4's Avatar
2blklt4
OK, i have same problem.
I found the clutch fluid container to the "add line" but no leaks in sight!
Where does the fluid go then?
Old Apr 3, 2005 | 05:57 AM
pwoolford's Avatar
pwoolford
St. Jude Donor '08
Mine leaked mostly where the plastic fluid container part attached to the master cylinder. When I took it off there was a little fluid leaking on the inside around the rod that goes into the master cylinder. I think that is the bad leak that can soak your carpet and make a mess.
Old Apr 3, 2005 | 01:06 PM
Rane LT4's Avatar
Rane LT4
I cannot find where mine is going either. There are some spots and runs on the inner hood that is tacky, but there is nothing on the engine to show that its splattering from there. Can someone give me a good site to buy what I need to fix this. I can probably get it cheaper than the dealer. And also show me exactly what I need to replace both. Thanks!!!!
Old Apr 3, 2005 | 02:13 PM
Cold_B's Avatar
Cold_B
I just noticed mine is leaking the other day, its leaking on the inside of the car. Its a very slow leak, but I just got my replacement in. I thought about doing the slave as well, and probably will.
Old Apr 3, 2005 | 04:52 PM
2blklt4's Avatar
2blklt4
Is the clutch fluid container FIXABLE/REPLACEBLE or the whole unit neeeds to be replaced?
Mine leaks at the bottom of plastic container.
I put some silicone arround the base but....
Old Apr 3, 2005 | 10:52 PM
2blklt4's Avatar
2blklt4
c`mon someone has to know...
Do i have to replace the whole unit that including the clutch master cylinder with the white little canister?
Old Apr 4, 2005 | 12:38 AM
bogus's Avatar
bogus
I really don't know if the canister is available from separately.
RTV is a good fix...
also, as of this time, no one is repairing those hydraulics.
Old Apr 4, 2005 | 03:16 AM
pwoolford's Avatar
pwoolford
St. Jude Donor '08
I actually tried to remove plastic reservoir from the new one to use on the old master cylinder (rather than replace the whole unit) but it felt like it was going to break instead come off. Aside from having to get the clip out under the dash the whole job was pretty easy.
Old Apr 4, 2005 | 04:43 PM
2blklt4's Avatar
2blklt4
Today i dropped off car to the shop.
I`ll have the clutch master and slave cyl replaced...
Better play it safe...my car needs to be perfect
Old Apr 4, 2005 | 09:26 PM
Rane LT4's Avatar
Rane LT4
Let me know how much they charged you. I need to get mine in sometime soon too. Thanks
Old Apr 5, 2005 | 02:57 AM
2blklt4's Avatar
2blklt4
$150 slave cylinder, $150 master cylinder, $200 labor, TOTAL$500
Old Apr 5, 2005 | 04:57 AM
ls5454's Avatar
ls5454
At least on my 90 L98, the rubber cup in the clutch reservoir displaces fluid every time you put the cap on and forces it down to the add line. Test it by adding to the full line and screwing on the cap, then removing the cap and rubber and rechecking. The fluid is forced out around the cap as you put it on.
Old Apr 5, 2005 | 05:38 AM
2blklt4's Avatar
2blklt4
in my case there was sippage at the base of canister where the plastic meets the metal
To Clutch Fluid ?
Old Apr 5, 2005 | 03:12 PM
bogus's Avatar
bogus
did they kiss you?
Old Apr 5, 2005 | 06:03 PM
Atok's Avatar
Atok
It will drop normally as the clutch disc wears, but not as fast as you say yours is. I usually top mine up each spring and then it's only down to maybe the "add" line.
Old Apr 5, 2005 | 08:24 PM
93ZF6's Avatar
93ZF6
There is a way to have both repaired the company is White Post restorations, they give a lifetime warrantee and sleeve the unit in brass along with a rebuild but it is not cheap, can you say GP? The whole system is a POS in my opinion this after 2 replacement slaves in a year due to a leak the size of a quarter on the floor. The fluid is going under the carpet pad if it is not going to the floor. It is a sealed system, ie: there is no real drop in fluid to be expected that is normal the fluid is going out of the system and will cause a synchro issue if not fixed. Check zfdoc.com for additional info and the price of a rebuild. the parts manager at ZF is named Benjamin Dover, we call him BEN DOVER!!
