95 window motor replacement
Old Apr 3, 2005 | 04:25 PM
barefootskier's Avatar
barefootskier
Cruising
Default 95 window motor replacement
my driver door window motor is frozen and will not move when smacked with a hammer. the factory shop manual says that the window must be removed first by lowering it to access the mount nuts and after the window is removed, to lower the regulator 3/4 of the down. the shop manual doesnt take in account for a frozen window motor. any suggestions on how to replace this motor? also the manual say that special tool #j 22055 is needed to remove the window nuts. anybody know what this tool is? is it just a torx or spanner nut socket of some kind? thanks for your help. scott
