Whew! Ignition problem solved quickly and easily!
Old Apr 3, 2005 | 06:46 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Whew! Ignition problem solved quickly and easily!
I've been doing a much needed clean up and detailing on my car this afternoon in preparation for our club showing at the Autofair down at Charlotte Speedway next weekend. Anyhow, I was moving the car around a lot to access different areas and all of the sudden when I went to start it, it would die as soon as the key was released from the crank position. Hmmmm, just like an ignition resistor failure on the older, simpler cars. So I checked all fuses that I thought may have been applicable, no problems there. Removed the dual connectors from the coil and found a little corrosion. Ah ha! Cleaned it up and reconnected, problem solved! Some days are better than others. Just wanted to pass it on in case anyone encounters this symptom.
Old Apr 3, 2005 | 06:49 PM
CFI-EFI's Avatar
CFI-EFI
Yea! Good catch.
RACE ON!!!
Old Apr 3, 2005 | 08:30 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
kewl
Old Apr 4, 2005 | 01:11 AM
Mo_Bandy's Avatar
Mo_Bandy
I had a simular situation where the contacts ha lost the tension and I had to replace the connectors... was not fun driving along and the car would just stop... (Especially in LA rush hour traffic.. that's an oxymoron)
I bought new plug and fixed it after happening twiggle te leads when the engine was running and it died...
Mo
Old Apr 4, 2005 | 01:31 AM
Corvette Kid
Mo
So where'd you get the connector? I'll always be paranoid now. It would be worth it for the peace of mind.
Old Apr 4, 2005 | 07:42 AM
runner140*'s Avatar
runner140*
Yea, sometimes we get lucky.
Old Apr 5, 2005 | 01:41 AM
Mo_Bandy's Avatar
Mo_Bandy
I got them from the GM dealer, like 13 bux ...
I again started it and wiggled the wires and the problem was solved...
Mo
Old Apr 5, 2005 | 02:06 AM
85 500 horse's Avatar
85 500 horse
Sometimes we get lucky and sometimes we don't. I'm happy for you that this was an easy, vastly inexpensive fix.
To Whew! Ignition problem solved quickly and easily!
