PE timing
Old Apr 5, 2005 | 02:44 PM
gbody5's Avatar
gbody5
Default PE timing
Could someone post the stock PE timing table for an 88 L98.
Thanks!
Old Apr 6, 2005 | 01:09 PM
gbody5's Avatar
gbody5
OK OK, ANY L98 PE timing tables, preferably AL headed engine though.
Thanks.
Old Apr 7, 2005 | 07:52 PM
gbody5's Avatar
gbody5
Anyone, anyone, Beuller?
Old Apr 7, 2005 | 08:51 PM
tequilaboy's Avatar
tequilaboy
From my 88 4+3 ABTR bin file:
0 degrees in the first cell (400 rpm), and 3.9 degrees everywhere else. This is a two dimensional table additional spark (at wot) vs. rpm.
Is this what you're looking for?
Sorry I don't have the table in front of me since my laptop is at work, but I took a look at it today after I saw your post.
Old Apr 7, 2005 | 09:44 PM
gbody5's Avatar
gbody5
Yep, that's the one. Mine is ACKY bin:
Power Enrichment Mode Spark Advance
RPM Degrees
4800 1.05
3200 9.14
2000 1.05
1200 1.05
400 0.00
Is this the same size table as yours or is there more to it? This is all I see with TunerPro.
Thanks,
Mark
Old Apr 8, 2005 | 03:55 AM
Blower91's Avatar
Blower91
RPM Degrees
4800 1.05
3200 9.14
2000 1.05
1200 1.05
400 0.00
The ACKY bin found in "stock" library at moates site has identical PE table as yours, perhaps you have already compared to this bin? Quite different to eg ANTH ($8D), wonder why...
Old Apr 8, 2005 | 09:35 AM
gbody5's Avatar
gbody5
I think that's my bin that I uploaded to Moates site. You nailed it, I'm trying to compare with other bins because I'm getting quite a bit of knock at WOT in the RPM range where it gets advanced so much.
What I would really like to know is if I'm seeing the entire table or if there is more data in it and it's just not defined further.
Thanks,
Mark
Old Apr 8, 2005 | 11:08 AM
Blower91's Avatar
Blower91
I think you are seeing the entire table. My "$8D-table" has also only 5 values. They are five consecutive bytes starting at address 81B3h. If the tables was larger than 5 bytes the rest of it would have to be far away from those 5 bytes and that (I think) is very unlikely.
Old Apr 8, 2005 | 11:34 AM
gbody5's Avatar
gbody5
Excellent, thanks for the information, now I'm going take some of the timing out and do a few test runs.
To PE timing
