Steering Wheel wobble on Right Hander
Old Apr 5, 2005 | 09:51 PM
djxib's Avatar
djxib
Default Steering Wheel wobble on Right Hander
I have a strange problem which seems to happen only when the car is cold. Going around a gentle right hand bend at about 50 mph sets up a fairly violent shaking/wobble of the steering wheel (almost as if a wheel is going to fall off). When the car warms up all is OK.
It sits for days at a time in the garage - only an occasional driver. I wonder if the tires are developing flat spots that rectify themselves after a few miles of driving?
I've checked the wheel nuts / checked for loose wheel bearings and all the suspension mountings are tight.
Anyone seen this before / ideas?
Thanks, Andy.
Old Apr 5, 2005 | 10:01 PM
Cherry6speed's Avatar
Cherry6speed
Mine does the same thing until the tires heat up. Are your tires like mine? Old but, plenty of tread? A fresh set will correct it but, it is fairly common with ultra-wide tires on weekend cars. In other words, save your money and warm the tires up.....
Old Apr 5, 2005 | 11:43 PM
rws.1's Avatar
rws.1
If it is not old tires with hard rubber that are losing traction while cornering when cold, then I would think you might be describing a front end alignment issue with the camber going from negative to positive and the tires chattering
Old Apr 6, 2005 | 09:15 AM
djxib's Avatar
djxib
Thanks RubyRed. Yes, old tires but plenty of tread. I'll just make sure they are warmed up. However I am going to double check all bolts etc. today and will go and get an alignment done this weekend.
Cheers!
To Steering Wheel wobble on Right Hander
