Had the GS dynoed today????
Old Apr 6, 2005 | 08:28 PM
GS 163's Avatar
GS 163
Default Had the GS dynoed today????
Had the GS on the dyno today. 299 RWHP/316 ft lbs torque. With the mods in my sig, does this seem right. I would think I could do better than this. Discuss please.
Old Apr 6, 2005 | 08:33 PM
Cold_B's Avatar
Cold_B
HP seems a little low, could have just been the dyno. Was it a Mustang or Dynojet?
That's not to far off my stats, and we have pretty much the same mods. I could see my flywheel making the 15ft lbs torque differance.
Old Apr 6, 2005 | 08:45 PM
GS 163's Avatar
GS 163
It was dynojet. From what I understand the 4.10s cause a slight loss in HP, but it still seems pretty low to me.
Old Apr 6, 2005 | 08:59 PM
TA's Avatar
TA
Sounds low to me. I thought most LT4s put down around 300 rwhp stock?
Old Apr 6, 2005 | 09:01 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
The 4.10's will drop the #'s a little, but this should be more than made up for with the longtubes with no cats. Did you get it tuned for the LT's w/o cats? If you are running 315's out back and/or have heavier rims, the #'s can be lower as well. I'd think youd be in the 320-330 range...
Old Apr 6, 2005 | 09:07 PM
GS 163's Avatar
GS 163
I have 315s out back, but Fikse wheels which are (or should be) lighter than stock. Baer 2 piece rotors which (I was under the impression are lighter than stock). Im not sure if they tuned it for no cats, will have to check, but Im sure I must be putting down more than this. I have seen a number of stock LT4s putting these numbers down.
Old Apr 6, 2005 | 09:39 PM
vader86's Avatar
vader86
The headers and exhaust work shouldve put you at about 320-330rw or thereabouts. I agree something is up, but some dynojets do read differently.
What did the curve look like, was it smooth or choppy?
Old Apr 6, 2005 | 09:55 PM
LT4BUD's Avatar
LT4BUD
I did 299rwhp with 4.10 gears....stock exhaust manifold & cats.....on a dynojet......other mods similiar to yours
My torque was also more or less same as your 316
Seems you are around 20hp low......did you record A/F....
What rpm did you get peak hp
Old Apr 6, 2005 | 09:56 PM
GS 163's Avatar
GS 163
The dyno curve is very smooth across the board, nothing looks out of the ordinary.
Old Apr 6, 2005 | 10:00 PM
LD85's Avatar
LD85
Was this with a stock bottom end
Old Apr 6, 2005 | 10:03 PM
GS 163's Avatar
GS 163
Stock bottom end, the mods are in my sig. The peak HP came at about 5600 rpm.
Old Apr 6, 2005 | 10:14 PM
LT4BUD's Avatar
LT4BUD
At 299 rwhp, internally the motor was all stock...........
The bottom end is still stock, but now many mods.....last dyno was solid 365rwhp.....since I have added long tube headers, high flow cats, aluminum damper with underdrive pulley.........dyno tuning coming May14...new hp=???
Old Apr 6, 2005 | 10:17 PM
LT4BUD's Avatar
LT4BUD
Sounds about right...but near stock motors usually peak right at 5800.......
Old Apr 6, 2005 | 10:30 PM
~db~'s Avatar
~db~
J...J...J figured i'd find you here Call me at work tomorrow (email if you forgot the number) and i'll give you some possibilities that i encountered.
Old Apr 6, 2005 | 10:34 PM
GS 163's Avatar
GS 163
Ill give you a call tomorrow, I still have your number.
Old Apr 6, 2005 | 11:41 PM
Cold_B's Avatar
Cold_B
Just to give you more info about my dyno for your comparision.
Mine was done on a dynojet, I have 315, on A-molds (not sure who made them), I have non-stock rotors (their cross-drilled and slotted, again not sure who made them), and my peak hp was at 5700 - 5900rpm (it varied by only .4hp over that range). At 5600rpm I was just .9hp lower than 5700 I still have the stock 3.45.
Keep us updated on what you find!
Old Apr 7, 2005 | 01:15 PM
Perfusion's Avatar
Perfusion
My numbers are in my sig along with my mods. Yours do sound a little low...
To Had the GS dynoed today????
Old Apr 7, 2005 | 01:18 PM
TM-Z06's Avatar
TM-Z06
Perfusion made 324hp/325tq with his stock LT4 with K&N, EM long-tubes, cats, and Corsas --- running very lean. I made 297hp/311tq with just Corsas and an X-pipe. With your headers, and no cats, you should be 20-25hp over stock.
EDIT:
Perfusion - we must have been posting at the same time
Old Apr 7, 2005 | 01:37 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
My LT-4 made 305 with 3.45s and stock exhaust manifolds on the same dyno that LT4Bud's made 299.
I agree you are a bit low. With the headers minus a touch for the gears, I'd think you'd be in the 310 to 320 range.
Old Apr 7, 2005 | 06:25 PM
~db~'s Avatar
~db~
Just FYI gents..the rear gears will not effect his peak HP. It may effect the RPM range at which he achieves peak numbers but as long as he maintains a 1:1 ratio (all relevant to the trans gearing which should be in 4th gear), it shouldn't be a factor
