New C4 owner - help??
1. Does anyone know where I can get an online manual. The previous owner is looking for the original manual that came with the car, but I expect I won't see it for at least a few weeks.
2. I noticed the car makes a buzzing noise from under the passenger glove box when I first unlock the door and enter the vehicle. It goes off as soon as I start the car. Is this normal and does anyone know what it is??
Thanks,
Jim
. You may want to watch for a helms manual on e-bay as well. You can usually pick them up pretty cheap. Good luck Rich
As an example, I have the Helms Corvette Shop Manual for my 86 and it's pretty detailed on MOST topics/areas, but recently I wanted to check my coil resistance and the diagram showing where to connect my ohm meter was not clear in the Helms manual.
Fortunately I have a Chilton book too (about $19.95 at most auto parts stores) and in that book, there were much clearer photos of where to connect my probes. This kind of thing comes up from time to time so having more than one reference manual is a good idea if you plan on doing your own work on your car.
No need to get a second mortgage to get them all at once (LOL), but as time passes you may want to consider picking up different versions.
There are a couple of monthly Corvette magazines that also contain a Tech Tips section, (in addition to lots of other GOOD info), that are really good for the do-it-yourselfer. Corvette Fever and VETTE are two of them.
If you want catalogs that offer parts specifically for Vettes, and not Mustangs and Chryslers, etc., there are several good ones. Eckler's, Mid-America, Corvette Central and Corvette America are the four that come to mind. I believe all of them are free and I believe they can be ordered on-line or by calling a 1-800 number. They'll give you all sorts of ideas on how to spend your hard earned $$.
As far as tools, most problems (and if you're like the rest of us, you're gonna have some) can be diagnosed with a Digital Volt Meter (DVM), a 12 volt test light and one of the data loggers that can give you real time data on what all the sensors are doing.
There are several different kinds on the market. Diacom is one of them, but it's kinda pricey, it plugs into the Assembly Line Diagnostic Link (ALDL) and reads out on a laptop as the engine is running.
Then there's a ScanTool that's available at AutoZone and other bigger auto parts stores. It's priced much more reasonably and gives about the same data as Diacom, but I don't know if you can save the data to a 3.5 floppy or not, which you can do with Diacom.
Anyway, other guys will probably chime in with their suggestions and preference on data loggers.
Hope this helps.
Jake
Hope this helps.
Jake
101 Corvette projects is a good book to have too. The search function on this forum is a great source of information too.
Jim
Jake
Thanks,
Jim
Sounds like one of the courtsey light relays. Check the courtsey lamp fuses with a DVM. I think they are 5amp and 20amp #'s 31 & 32. Is your PKE system working?
Edit note: Early model 93's don't have the programmable computer. You can tell by looking at the box just above the battery. If its a smooth black case you have the early model, if it has cooling fins and is brushed metal look you have a later model.
If you want to pull DTC's (codes) you can easily do it with a paper clip jumping the correct pins, there are several which displays the DTCs for each system.
. You may want to watch for a helms manual on e-bay as well. You can usually pick them up pretty cheap. Good luck RichThe buzzing noise is an indication that a fuse is blowen. Ive had personal experiance with this a few times. I also have a 93. The fuse box is located on the passenger side of the dashboard, on the side. its a smooth black cover that comes off. you will have to open the pass. door to get to it. unfortunatly you will have to look at every fuse to see which one is blowen. unless you can see whats not working on your car. try everything interier lights. Dont forget the light that is in the rearview mirror. thats where mine was.
Hope this helps.
Thanks all!!
Jim
