Steering Wheel Question
Old Apr 7, 2005 | 10:50 AM
WildBill95's Avatar
WildBill95
Default Steering Wheel Question
Hi all , I`ve got a 95 coupe and the steering wheel is about 1/8th off when going straight down the road . The question is can this be corrected by removig the linkage from the rack and pinion and turning the wheel straight or does the steering wheel need to come off and if so should I be concerned with setting off the air bag ? Thanks
Old Apr 7, 2005 | 11:06 AM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
whoever did your front end alignment did not center the steering while performing the alignment. that, or you knocked the alignment out
Old Apr 7, 2005 | 11:32 AM
chaos on wheels's Avatar
chaos on wheels
Get a 4 wheel alignment.
It could also be the rear wheels which are off.
Old Apr 7, 2005 | 11:41 AM
WildBill95's Avatar
WildBill95
Thanks , it`ll get an alignment .
To Steering Wheel Question
