Battery Drain
Not driven often, but a least 20 miles once a week.
Yesterday, dead battery. Put on charge for 10 minutes, starts right up.
Dash reading shows 14.1 - 13.9 - 13.1 charging, etc., this is right after charging and stays that way while driving.
Come back home, stop the car. Five minutes later, battery dead again.
I have tried the float, trickle charge, stayed on 48 hours, no help.
It has been doing great, keeping a charge, then suddenly, dead.
Any suggestions? Do a good deep cycle 10 amp charge for 48 hours?
Boatman
just before that, did you have a float charger
hooked up? If so, could the FC maintain 13 volts?
You should not let the batt go dead.
Do you own a digital voltmeter?
Thanks for reply, looking for fix,
Boatman
Hobe Sound, FL
Boatman
Hobe Sound, FL
Vette Show: Fort Pierce, FL, about 12 miles north of Stuart, Rt 1.
Register at: www.stuartcorvetteclub.com
I would think that with low leakage current and a 20 mile drive each week would keep the battery up. Harbor Freight sells a battery tender for $7 I believe. If you already have a battery charger you can buy an interval timer (turns your home lights on when you aren't there) and have it charge your battery each day for its minimum interval (usually 15 mins). An hour a day won't hurt your battery.
I have two... and bought additonal ones for my Brother's ATV.
Best investment under $10 I have ever made.
I have a small building in the back that I keep radio control equipment in, with air and a de-humidifier. Get a large one for the garage where this car sits may help.
Thanks for reply,
Boatman
