cooling 180° or 160°
And doing this would avoid excessive cylinder wall wear?
RACE ON!!!
Follow Jackdaroofers advice below.
You should look at using a hi flow balanced thermostat (such as Cobra Valley http://performanceunlimited.com/cobr...hermostat.html )
These type of thermostats operate with 2° of accuracy and fail to the open condition.
I installed A Hypertech Thermomaster chip in my car along with the 160* stat and my car ran slower in the 1/4 mile. It was the chip, not the stat. Forget the 160* stat unless you take it to the track, often, and go to the trouble to cool it between rounds. On the street, a cooler stat will not make the car run cooler. It will only serve to make it take longer to warm up. Think about what it is that a stat does. My guess is that for your usage, the 195* stat and earlier fan on temps would work very well. The 180* would be OK. Don't go to a 160* stat unless you have a dedicated purpose, understand the consequences, and alter your maintenance schedule accordingly
and
It would be more like 1500 to 2000 miles. The more frequent oil changes will get the moisture and acids out of the oil pan that isn't being boiled out by sufficiant temps, for sufficient periods of time. The extra cylinder wear is pretty much unavoidable, as it is caused mostly during warm up, which is extended by a too cool thermostat.
END QUOTE
My '88 has had the Hypertech chip and 160 stat combo for over 15 years. I don't run the drag strip so this wasn't ever a concern. I like the early fan turn-on (170) and the delayed converter lockup and I wouldn't go back to stock chip and temps for anything. I have the front and rear fan wired to come on together. My car rarely sees 180 in traffic and never 190 with the ac on. Granted the car has less than 60k but I only change oil (weaned on Mobil 1) once a year and the engine looks like new with the valve covers off and has the same compression as a decade ago. Yes, the cooler stat lets my car run cooler. No, it doesn't take longer to warm up (not to the current operating temp). Why would it? It actually takes less time to reach a steady 160.
CFI-EFI, I have the most respect for your knowledge. But where are you guys getting your facts? This subject has come up years ago when I worked for GM with engineering. Going from 180 to 160 is hardly enough to alter the time to remove moister from the crankcase. Insuficient driving time is harmful no matter which stat you choose. Moisture and acids do not mix with synthetic like it does with petroleum oils (forming varnish and sludge), maybe a reason for my car's longevity.
If you can show me hard facts to reveal otherwise, I'll concede. Otherwise I've been around too long to believe differntly.
RACE ON!!!
http://web.camaross.com/forums/showt...=coolant+temps
read the reply's by "injuneer"
I thank those who did give valueable responses (ie. CFI-EFI, korvette4u, vader86 to name a few). Please keep it up.
99svrcpe, that is a great link. "injuneer" knows his thermo dynamics and hasn't seemed to confuse theory with urban myth.
Then if I go to a road course, I can be at 210-220 oil for 20 minutes.
I would think this would light up anything in there? It didn't get that hot w/the stock stat if not run hard, especially in winter. In fact, I can remember, on cold winter days it used to get to 190 oil only. I don't drive it in winter anymore so it doesn't see this usage.
So am I right in thinking that using the 160 is just like driving your car in cold weather (say 0 deg. F)?
Personally, I don't like to see my oil temps under 200*. It takes me about a half hour of freeway cruising at moderate ambient temps to get there. And as you asked, and I partially answered, the temperature of the oil would be a factor in "What's sufficient time?". The hotter the oil, the quicker the containments will evaporate or boil off.
Driving with a cooler stat is not like driving in cold weather. With a 195* stat, the water is going to stay in the block until it gets to 195*. It doesn't matter if it is 0* out or 120*. The water is forced to reach the set temp before it is subject to cooling. If it is really cold, and the radiator cools the water to 195* or below, the stat will shut and maintain that minimum water temp.
The purpose of a thermostat is to provide quick warm ups. If a cooler stat is used than the eventual operating temp, the stat is stopped short of completing is job. After the stat is open, it is as though it doesn't exist. A point for all to remember, is that the stat only controls how cool the engine CAN run. It establishes the minimum operating temp. It has no effect on how hot it can run. Once it has opened, it has no control over how hot things get.
I hope that answers your question. If not, I'll make another run at it.
RACE ON!!!
RACE ON!!!
Whoa, CFI-EFI. I didn't mean to upset you. Like I said earlier there was no intention to diss your knowledge. I was merely showing what works for me and over time still does.
Jim
Jim
Those statements, indicate a lack of understanding on what the thermostat does and how the cooling system reacts. I'm afraid I can't allow them to remain unchallenged, to protect the innocent.
You make a point of your experience. If YOU are happy with what you've done and how it does or doesn't affect your engine, then there is really nothing more for me to say. If you are happy, then that's all that counts.
RACE ON!!!
