? on code 43 and power loss
Old Apr 9, 2005 | 05:05 PM
C4Ownr24's Avatar
C4Ownr24
Default ? on code 43 and power loss
For the past month or so, I've been experiencing a weird condition where I have an absolute loss of power....it's intermittent - @ WOT, sometimes it will feel like I'm driving a honda civic. Then all of the sudden it will pick up to normal performance. The vehicle hasn't thrown any codes at all during this time. Then, the other night, as I was pulling out of a filling station, I punched it - the car backfired a bit through the intake, and the check engine light illuminated. It was a code 43 - something to do with the ESC module or knock sensors. It seems weird to me that this is the first time the light would go on (seeing as how this has been happening for a month or so....)
Where does this code point me? Has it been anybodys experience that it is more than likely a knock sensor issue or is it more than likely an ESC module issue? I have the flow chart, just don't have a meter or any of my tools @ the house. Any help is appreciated.
One thing i will mention - this problem started around the same time (i think) as when I sawed off my exhaust right after the cat - could a real loud exhaust cause this condition? Just an idea.
Old Apr 10, 2005 | 11:34 AM
C4Ownr24's Avatar
C4Ownr24
somebody? anybody? can a loud exhaust cause a false knock reading?
Old Apr 10, 2005 | 01:58 PM
Sliding's Avatar
Sliding
I had the same situation on my '90.
It turned out it was bad connection on knock sensor.
I broke the connector and welded the wire directly to
sensor and no problems since than.
There is a procedure on testing knock sensor but I'll have to look
up for it.
Old Apr 10, 2005 | 02:03 PM
Sliding's Avatar
Sliding
Yeah, I've heard that headers or very loud exhaust could
cause false knock but I don't have that problems on
my vette and I have headers, and straight pipes with just
two small mufflers in the back, so I don't think you could
go much louder than that.
Old Apr 10, 2005 | 11:25 PM
mikey whipreck's Avatar
mikey whipreck
I dont think he mentioned it-
but the reason for your power loss is that after a code 43 is set (i.e. when your check engine light comes one) the computer retards your timing to whatever your base timing is (probably 6*)... so you drop from 20* or whatever EST timing is, to 6*
EDIT:::
BTW- my experience iwth a code 43:
replaced the sensor,
replaced the wiring and connector,
replaced the ESC module
STILL got code 43
disconnected the knock sensor (on advice of CFI-EFI)
STILL got code 43
Old Apr 10, 2005 | 11:59 PM
C4Ownr24's Avatar
C4Ownr24
well so what did you end up doing to resolve it?
To ? on code 43 and power loss
