Resetting Oil Change Light
Old Apr 10, 2005 | 04:31 PM
RONJON851's Avatar
RONJON851
Default Resetting Oil Change Light
I Don't Have A Manual And Need To Know How To Reset The Dash Light For Oil Change.i Changed Oil And Thought You Press The English/metric 3 Times And Then It Will Start Blinking And Then It Will Reset.thanks For You Expertise!!!!!
Old Apr 10, 2005 | 07:03 PM
TrackDayLT4's Avatar
TrackDayLT4
For my '96 it is as follows;
1) turn key to run
2) Press ENG MET twice within 5 seconds
3) within 5 seconds press and hold GAUGES until CHANGE OIL light stops flashing and goes out
Cheers,
Lawrence
Old Apr 10, 2005 | 07:52 PM
65coop's Avatar
65coop
St. Jude Donor '05
1. Turn the key to the "ON" position, but don't start the engine.
2. Press the ENG/MET button on the Trip Monitor and release it. Then, within five seconds, press and release the ENG/MET button again.
3. Within five seconds, of Step 2, press and hold the RANGE (1990-1991) button or the GAUGES (1992-1996) button on the Trip Monitor. The CHANGE OIL light will flash.
4. Hold the RANGE or GAUGES button until the CHANGE OIL light stops flashing and goes out.
When the light goes out, the Engine Oil Life Monitor is reset. This should take about ten seconds. If it doesn't reset, turn the ignition "OFF" and repeat the procedure. If you remember to follow the procedure after every oil change, you should never see that light again.
To Resetting Oil Change Light
