Question about brakes
Old Apr 10, 2005 | 06:44 PM
convertible lover's Avatar
convertible lover
Default Question about brakes
I went on a little fun run with a group today. After a little mountian road driving, car drove great, brakes worked great, got to the bottom of the hill at a stop light. After the light finely turned green I moved about a car length, hit the brakes because of a dip, brakes went to the floor. I pumped the brake one time and had a good pedal again, pulled in to a parking lot every time I hit the brakes same thing, had to pump the pedal to stop. Went in had lunch. After lunch brakes worked fine, after cooling. Question What would cause this? Brakes are new just put on new rotors and pads on the front. About two hundred miles on them. Could it be the fluid is bad, old. If that is the trouble, could anybody tell me how do you exchange it out with new. By the way it is an 87 convertible. Thanks Jack
Old Apr 10, 2005 | 07:07 PM
sniperdiver37's Avatar
sniperdiver37
Sounds like you got the fluid hot. When you do that it pumps the hot fluid into you stock rubber brake lines. When that happens the rubber gets soft and expands more. Thats why most of us use SS braided lines, no flexing.
Try shifting to a lower rear when coming down long hills. let the motor and trans do the work.
Old Apr 10, 2005 | 07:09 PM
sniperdiver37
PS.. when you go get your new SS lines be sure to flush out all the old stuff. Not a hard job, let us know and help will be here.
Old Apr 10, 2005 | 07:13 PM
MYCoupe's Avatar
MYCoupe
Agree, sounds like you were suffering from brake fade. Make sure you flush out the system and use some high quality fluid that has a higher boiling point. Another solution is to upgrade to the C5 brakes.
Old Apr 10, 2005 | 07:28 PM
convertible lover
To flush out the system, do you do the same as when bleeding for air? Just keep going till the fluid looks new.
Where is a good place to get the SS brake lines and about how much should it cost?
Old Apr 10, 2005 | 08:01 PM
MarkBychowski's Avatar
MarkBychowski
should it cost?
Exactly.
I bought my SS lines from doug Rippie ( www.dougrippie.com ) but there are a lot of places that sell them. Can't remember the price.
Old Apr 10, 2005 | 08:12 PM
sniperdiver37
Got my russels SS lines from summit racing. around $100.
To flush the fluid , yes just like bleeding brakes, keep bleeding until it's clean. You can buy a kits to do this at your auto parts store. Do some reading and talk to folks about the best fluid. Some say synthetic, some just OEM fluid. Thats your choice.
Old Apr 10, 2005 | 08:25 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I really like Valvoline "synpower" brake fluid
I run it hard and brake hard aand no sign of overheating the fluid
Jack
Old Apr 10, 2005 | 09:17 PM
convertible lover
Thanks to all. Looks like I have a job for next weekend. Thanks again Jack
Old Apr 10, 2005 | 10:12 PM
rws.1's Avatar
rws.1
Valvoline Synpower is Dot 3+ DOT 4...
I swtiched ot it a year ago. glad I did.
Old Apr 10, 2005 | 10:15 PM
MYCoupe's Avatar
MYCoupe
Yea, that's what I used when I upgraded to the C5 brakes. So far they are working great.
Old Apr 10, 2005 | 10:30 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If you lost pedal pressure, it's leaking past the m/c, or the fluid is boiling.
Check the fluid level. If that's ok, it maybe water in the fluid vaporizing, which reduces line pressure. (and corrodes everything too).
If the pedal was firm, but it just didn't stop, then it's brake fade. That has nothing to do with the fluid or brake lines. It's when the rotors and pads overheat and lose their friction coefficient. Only way to fix that is upgrade to heavier rotors or change your driving habits.
Old Apr 11, 2005 | 09:11 PM
convertible lover
The pedal was not firm, It went to the floor, only had pedal after I pumped it once. I know that is a sign of air in the lines, but it only did it after it got hot from the mountain run. So I would guess it is water in the fluid like you said. I think I will change the lines anyway just to be safe, and of couse that would mean changing the fluid while doing it. Is there anything else I would need besides the lines and brake fluid? Thanks.
Old Apr 11, 2005 | 10:21 PM
larryfs's Avatar
larryfs
you need a master cylinder, plain and simple.
the stock C4 brakes work fine for what your doing.
Old Apr 11, 2005 | 10:46 PM
88vettelover's Avatar
88vettelover
I disagree. If he lost his pedal completely, and then pumped it and it held, then it's not the master cylinder. When the master cylinder is bad, you can pump it back up, but it will fade right back down.
I think it's just fluid boiling. Brake fluid absorbs water, plain and simple. A sealed container of brake fluid will be about 5-20% water after one year. It absorbs moisture through containers which means a fluid change will suit you well.
As for everyone blaming the hoses, maybe, but I don't think so. I worked on brakes for a long time, as a job, and most of the time, unless the hose has split open, when a hose goes bad, it doesn't want to release. The internal lining breaks down and doesn't want to cause the fluid to return to the cylinder, causing a bad pull and definite heat.
Here's some easy steps for a hose check. Jack the car up. Have someone sit in the car. Spin one of the wheels by hand, and have the person in the car hit the brakes. The wheel should stop of course, then tell them to release. Once they release, try turning the wheel with your hands. It should spin freely, if not and it is very hard to turn or won't budge at all, bad hose.
Hope that helps and good luck!
Old Apr 12, 2005 | 09:14 AM
mitchcole's Avatar
mitchcole
Change the fluid first - it's a cheap fix if that's the problem. Other than that - the pumping up of the pedal is classic master cylinder failure.
p.s. When you change pads: don't squeeze the fluid from the calipers back up to the master cylinder - always bleed the fluid off out of the bleed screw. Othewise - all the crap from the calipers end up in your master cylinder causing premature failure.
Best of luck to you!
Old Apr 12, 2005 | 10:17 AM
C10 JDR's Avatar
C10 JDR
Thats why people upgrade to C5 brakes
Old Apr 12, 2005 | 05:51 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Kevin is right on.
It sounds like you boiled the fluid. Just flush/refill with Valvoline Synthetic.
The fact that the problem was gone when the system cooled tells me the master cylinder was not at fault.
Oh, yeah, there is one other thing you can do to stop fade, besides changing rotors or habits; change to a good ceramic pad. Worked for me.
...and I don't think it's a hose problem either. SS hoses will give you a better pedal feel, but they can't stop fade or fluid boiling.
Larry
code5coupe
To Question about brakes
