Clutch friction point
Old Apr 11, 2005 | 08:21 AM
cresus's Avatar
cresus
Default Clutch friction point
So I just changed the clutch on my '94 LT1. I'm a little concerned because the friction point on the clutch seems really high. When I shift it doesn't engage until I've just about pulled the pedal all the way out (maybe 1/2 inch depressed). This doesn't seem right and it seems that when it wears a little it's going to start slipping because it's so close. Am I seeing this wrong? Where's the friction point usually? Thanks for the help.
Old Apr 11, 2005 | 12:58 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
did you just change the clutch disc, or the entire combo (disc, pressure plate, t/o bearing). was it a matched set?
Old Apr 11, 2005 | 03:26 PM
cresus's Avatar
cresus
Entire combo...I'm unsure of how it should feel because the old setup had a backed out pivot stud that required more pedal travel (logically) than it should have. So I'm trying to see what people have normally. Thanks.
Old Apr 11, 2005 | 03:46 PM
Yellow95's Avatar
Yellow95
On hydraulic clutches, they are supposed to engage near the top of pedal movement. As the clutch wears the contack point gets lower. Add some fluid and it comes back up again.
Mine grabs near the top.
Old Apr 11, 2005 | 05:46 PM
cresus's Avatar
cresus
Awesome...thanks. I was worried I had no play left.
To Clutch friction point
