leaking pcv valve...
Old Apr 11, 2005 | 04:05 PM
texan0218's Avatar
texan0218
Default leaking pcv valve...
after i cleaned up my valve covers on my 86 i noticed a couple of days later the drivers side is covered in oil again. it is coming from the pvc valve. is there any ay to fix this? it is not a major problem, not that much leaks out, but i would like for the covers to stay clean. would replacing the valve help at all?
Old Apr 11, 2005 | 04:28 PM
CFI-EFI's Avatar
CFI-EFI
It depends on EXACTLY where it's leaking. The odds are that the grommet has become hardened from heat and age. Check the grommet before you buy anything.
RACE ON!!!
