Headlight Controller Module Question
Old Apr 12, 2005 | 05:13 AM
Vetteboy77au's Avatar
Vetteboy77au
Default Headlight Controller Module Question
Hi All,
I just purchased a '92 headlight controller module to upgrade my 86. I have converted the headlights to a 2-wire setup however I am having a few issues. Can someone please confirm for me the connections on the 5 pin connector.
Chris
Old Apr 12, 2005 | 01:18 PM
Hooked on Vettes's Avatar
Hooked on Vettes
Connector C2 looks like this.
_____
(__A__l Yellow wire Hot/ Headlight switch is in Head
l__B__l Red wire 12 volt Fusible Link
l__C__l White wire Hot when headlight switch is Off
l__D__l Black wire ground
(__E__l Red wire 12 volt Fusible Link
If you mounted the controller on the front of the driver side plastic wheel well housing and the 5 pin connector is on the driver side and the 4 pin connector towards the frame side. The C2 connector from top to bottom wires look like this.
Yellow
Red
White
Black
Red
