Flywheel problems?
Old Apr 12, 2005 | 03:36 PM
Silver 96's Avatar
Silver 96
Default Flywheel problems?
My li'l car is in the shop to get a new clutch, and the shop owner tells me that there is a vibration which they suspect is because of a problem with the dual mass flywheel.
I have an LT4 with the LPE 383 conversion, so the shop owner phoned Lingenfelter to get their take on the problem. Apparently, LPE have been noticing problems with this flywheel, although in '97 when my engine was converted, the dual mass flywheel was relatively new and LPE thought it was good enough.
I was wondering if anyone else here has had problems with their flywheel, especially those with stroker engines. If so, what did you replace it with?
Thanks!
