Need Some Tips
Old Apr 12, 2005 | 07:34 PM
88421VETTE's Avatar
88421VETTE
Default Need Some Tips
I'm going to take my Iroc to the dragstrip in a couple weeks. what are some of the things you guys do before going to race. like where should I set my timing. Are there any secrets I don't know about for L98's. I'd really like to have my car run high 14's and any tips would be great.
Old Apr 12, 2005 | 07:43 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If your IROC is like my '86 IROC it's about 300lbs heavier than my '88 Vette, which means .3sec slower.
If the IROC is stock you may have problems launching, which will result in higher 60' times and so higher ETs.
I did some small bolt on mods to my '86 IROC with a LB9 motor to get it into mid 14s. I also did some chassis mods to aid hook up.
I run my base timing at around 8deg BTDC.
Do a short dry burn out, bring idle up to around 1,000-1,200 rpm (if an A4) and launch it hard.
Just take it to the track and see what it runs.
Old Apr 12, 2005 | 07:59 PM
JAKE's Avatar
JAKE
Here's my advice:
If you'll be running brackets, where you dial in your own ET, SHOOT FOR CONSISTENCY.
No matter how quick or fast your car is, consistency is the key to winning.
You'll want to try to do exactly the same thing each run; from burn-out to crossing the stripe. Try to have the engine at the same temp. If you brake torque, use the same RPM; leave when you see the last yellow; if you wait for the green, you'll be late.
Try to get at least two time runs, preferably three before competition begins. Don't change anything or you'll introduce variables that will probably effect consistency.
Try to keep everything the same from one run to the next. For example, if you try lowering tire pressure, you may end up running quicker, causing you to break out.
At the tree, REMAIN RIGIDLY FOCUSED and don't be concerned about the guy in the other lane, just do YOUR THING. Don't be thinking stuff like, "OH, that guy is a LOT faster than me", pretend he's not even there.
Let the trans shift by itself; leave it in drive and let it do the shifting. The removes variable in the equation.
Once you been to the track a few times and become moe confortable you can begin tweaking stuff, but for right now, keep it simple.
Above all, HAVE FUN. That's what it's all about.
Jake
Old Apr 12, 2005 | 08:16 PM
88421VETTE's Avatar
88421VETTE
I took it to the track last year and ran a 15.5 which is about 14.7 at sealevel. the only mods I've done are chip and exhaust. this year I swapped the 2.77's for 3.42's. the engine is stock with 150k on it. not to bad considering my vette ran a 15.3 with a K&n and flowmasters.
Old Apr 12, 2005 | 08:17 PM
CFI-EFI's Avatar
CFI-EFI
Easier said than done, racing at 4400'.
Three time trials??? THAT'LL never happen at RMR. Actually, I think it happened to me...once. It was a blue moon that month. One TT, many times, but three ain't gonna happen.
Good luck and have fun.
RACE ON!!!
To Need Some Tips
