No "Low Coolant" Light ???!!!
TIA,
Ed
I'm really kinda worried about this, as I gotta have the car ready to go by tomorrow night
Any ideas?
TIA!
Ed
As long as the coolant level in the tank is just below the lip where the gasket on the cap sits and there are no leaks in the cooling system, you should be OK in terms of the system operating properly. 201 degrees is OK at cruise but keep the temp display up and watch for wide swings. Check the radiator and A/C condensor for dirt and debris and flush them out with a stream of water going from the engine side of the radiator through the fan shroud.
The sensor is part of the expansion tank and is not servicable by itself; you have to replace the whole tank. When you have time, you should check the bulb in the DIC.
http://corvetteactioncenter.com/foru...ht=low+coolant
No bulb test is done when you turn the ignition on.
One side of the (Low Coolant light bulb) goes to 12 volts. The other side of the light bulb get's grounded when the Low Coolant Switch shorts out. (When coolant doesn't cover it) so the Low Coolant light turns on.
If you want to test the light bulb in the DIC, unplug the connector and take a paper clip and short the two wires on the plug. Turn the ignition to Run and the light should be on.
There was a bulb test (Low Coolant) for 89 and older C4's.
They used a 1 wire sensor mounted in the radiator on the passenger side. The sensor then went to a Low Coolant Module which controlled the Low Coolant light.
The bulb is a type 74
To replace a bulb note its position on the silk screen.
Disconnect the negative battery cable.
1) Open center console lid and lift up the felt at the front of each corner. There will be two hidden bolts you need to remove.
2) Close the lid and open the ash tray lid. Remove the ash tray cups. Under one of them will be a bolt you need to remove.
3) Place a towel on the center console lid so you don't scratch it up and lift up on the shifter bezel and pull back so you gain access to remove the bolts holding the radio trim bezel.
4) Remove the bolts holding the radio trim bezel and pull it straight back.
5) Remove the bolts holding the DIC to the dash.
Unplug the connectors. Look at the back of the DIC and you'll see the socket holders for the bulbs. Give the holder a slight twist and the socket will come out.
Replace the bad bulb and reassemble everything.
