I tried to start my 94 Sat would barley run havn,t had a chance to pull codes then wooried about the dreded oti but it hasn,t been wet its been sitting for 2 weeks and was fine when i parked it but Sunday eve i noticed the fuel fill door was full to the top with rain water where the tree fuzzeys had clogged the drain do think it couldd have gotten water in the tank it was all around the cap .Imight have to drain it also thanks
Water floats on top of gas, so if it is doing that while idling then you have other issues. If it does it while driving, you have water in your gas and that will cause your problems.
Also, have you done something in the engine compartment, you might have knocked a vacuum hose off or disconnected a sensor.
