'95 383 project, tuning tips needed.
Old Apr 13, 2005 | 12:25 PM
ALLT4's Avatar
ALLT4
Default '95 383 project, tuning tips needed.
Final comp. ratio w/58cc 10.8
For now the stock heads which have been ported and gasket matched to an LT4 intake will be used.
Comp Cams 276HR-12 full roller setup with 1.6 ratio rockers.
The basic questions are...
Are the stock injectors fine? I think they are.
Would an LT4 knock sensor and module be necessary?
What problems can be expected in the stock tune with this combo?
Any other advice?
Old Apr 14, 2005 | 05:39 PM
Blower91's Avatar
Blower91
I make a WOT run and look at the duty cycle, it should not reach much more than 80-85% (if playing safe). If A/F ratio etc are all fine I think the injectors are big enough. If you are close to 100% your injectors might be too small or you might have some other problem.
Seems fairly common to use the LT4 knock module if running with roller rockers, I have no experince with this myself though.
I strongly recommend a "custom" chip. Eg, often strokers require less spark advance. You might get some knock problem with stock SA tables. Not sure about the LT1 but in my case (L98, $8D) you must change engine displacement in the chip, I think this is important!
Hope this helps!
