LT4 Heads
Apr 13, 2005 | 02:50 PM
LT4 Heads
I bought a used set of LT4 heads and am having a valve job done and new springs before I install them. They had 118,000 +\- miles on them. Am thinking of using the stock GM gaskets unless someone has a better suggestion. Or anything else I haven't thought of yet.
Jim
Apr 13, 2005 | 02:58 PM
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
You mean reusing the stock GM head gaskets? Not a good idea.
I just did head gaskets on my LT-1 and I used the Fel-pro 1074. Looks nice and was recommended here by a few.
Apr 13, 2005 | 03:36 PM
supposedly if you use the impala head gasket it boosts your CR and give you a couple of horsies... if that matters to you.
Apr 13, 2005 | 06:17 PM
Quote:
That is correct. Impala SS head gaskets are a touch thinner and are worth a bump in compression. Just get the Felpro ones...
Apr 13, 2005 | 07:36 PM
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Stock LT1/4 Corvette gaskets .049"
Felpros LTx replacements .039"
Impala LT1 gaskets .029"
These are compressed thicknesses. I used the Impala gaskets, why not? Good for about .4 increase in CR over the factory gaskets, I'm told.
Apr 13, 2005 | 09:51 PM
Gaskets
Thanks for the replys. No I wasn't going to use the old ones. But the Impala SS ones sound interesting. I'll have to think about that.
Jim
Apr 16, 2005 | 01:42 PM
Heads
decided to go with the Fel-Pro's. Any advice on replacing the head bolts? About $21 per head I've found.
thanks
Jim
