D#@&! How do I fix it now? 87
Old Apr 14, 2005 | 12:13 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default D#@&! How do I fix it now? 87
I was fixing a broken vacumn line that broke when I removed the plug wires. I inadvertantly snapped off the plastic portion of the brake pressure switch when I leaned on it with my elbow! I have ordered a new switch from the local GM dealer but how do I get the remainded of the switch out? It has plastic threads and is broken off at the top of the master cylinder.
Any help is greatly appreciated.
Old Apr 14, 2005 | 12:47 AM
bogus's Avatar
bogus
I would bust it out. Remember, plastic is softer then aluminum. I suspect you could get a screw driver in there and just tap it out.
Old Apr 14, 2005 | 01:21 AM
scorp508's Avatar
scorp508
Try putting some small needlenose plyers in there and open them while turning counterclockwise. Might work, might not. If it doesn't then just bust the sucker out and try to make sure you have ALL of the pieces.
Old Apr 14, 2005 | 02:29 AM
Morley's Avatar
Morley
How about just using a large easyout?
Old Apr 14, 2005 | 03:39 AM
VetteNoob's Avatar
VetteNoob
Use a X-Acto knife and carefully cut it into 2-4 pieces you can cleanly pull out using pliers.
Old Apr 14, 2005 | 03:50 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Same way as a pipe easy out and take it slow.
You can also try the home depo,they have easy outs for sprinkler systems and it should do the job.
To D#@&! How do I fix it now? 87
