Check your overflow tanks!
Well - I think I have tracked it down!
The following was replaced during the rebuild:
Radiator
Engine
Hoses to and from the radiator
Heater hoses
Water pump (new with engine)
Heater hoses to the heater core
Now, the heater core had not been replaced (I am not into S&M). There is no smell inside the car and no dampness in the carpets, two major signs the heater core is leaking.
Last nite I checked the expansion tank. It was the last place (short of me making some stupid mistake and not torqueing down the heads right) to check.
The tank was ok... BUT! The cap was NOT! The cap has a cork seal. The seal, a nominal 1.25" ID, was missing a chunk, about 3/8" long! And the gasket was wet! Think teakettle. The hot coolant expands into the tank. The steam vapours off through the missing gasket. Over a couple of weeks, enough coolant is vented off to cause a low coolant condition during operation. It also steams off, not boils off. It also compromises the systems pressure, but that's to a lessor extent.
I didn't have a gasket, but I had a nice fat oring, that I then wrapped around the neck of the expansion tank. I will now monitor the situation.
Thoughts?
Thoughts?
I think that it would be a vented cap anyway. There is no way that it could be a fully closed system. Once the coolant starts going into the overflow the air in the contaier has to go somewhere or it would rupture eventually. I guess it would have to depend on the cap. The venting would stop the flowing spilliage that the gasket stops as well, but I am not sure that it would stop the evaporation or the steaming off. It might slow it down a great deal more though...
RocketSapp
Unfortunately I think you may be prematurely happy.
Just FWIW.
I shall monitor.
Loss of coolant at the cap would at most be very incidental IMHO. I have cut a new cork gasket for mine. I get some dribbles of coolant there when I race due to the sloshing around, but it's minor.
Hope you find the leak.
