Change oil light
Old Apr 15, 2005 | 01:59 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Change oil light
Shouldn't disconnecting your battery make the change oil light go out?
My trip monitor is bad, so I can't reset it the normal way.
Old Apr 15, 2005 | 02:25 PM
bogus's Avatar
bogus
that should.
Old Apr 15, 2005 | 06:29 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
On my friend's '2000 Camaro I had to press and hold the Trip Reset **** (with ignition On) till the Change Oil light flashed and then went out.
Directions on this were in her owner's manual, give that a look.
To Change oil light
