Tricks to pulling rear ABS Sensor?
Old Apr 16, 2005 | 07:29 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Default Tricks to pulling rear ABS Sensor?
I'm throwing a code 35 on my 92 that relates to the LR sensor.
"Theoretically" you are supposed to be able to remove the bolt and bracket and remove by hand. Not happening.
Since I want to check it and the toothed wheel for dirt and crud before buying a replacement I don't want to go crazy with the vise grips.
Anyone run into this before?
Old Apr 16, 2005 | 09:17 PM
BillSF49's Avatar
BillSF49
I have a 94 and I just removed and cleaned both of mine. They both had so much crud on them, it was a difficult job getting them out. I sprayed some brake caliper cleaner around the bracket, the cleaner loosened it up just enough to remove by hand. I worked it side to side, and it came right out. You may have to spray it a time or two to loosened up the grime. Mine was pretty caked up. Hope this helps.
Old Apr 16, 2005 | 10:54 PM
Blue 92's Avatar
Blue 92
Thanks. I tried it with WD 40 but I've got some carb cleaner I'll try.
Old Apr 16, 2005 | 11:37 PM
jdbxyz's Avatar
jdbxyz
Mine were really frozen in place. I finally used a screwdriver and pryed on the flange a little at a time and worked my way around the sensor rocking it slowly out. One note on cleaning, I sprayed with WD-40 and cleaned with a rag and the codes went away but came back a few weeks later. I read somewhere to brush the end with a wire brush and I did that and have been code free since December. Good Luck.
Old Apr 17, 2005 | 08:22 AM
BillSF49's Avatar
BillSF49
I am not sure how good the carb cleaner works, but the brake caliper cleaner removes as you spray, it is pretty powerful stuff. Remember you can reach the sensor from the underside. I sprayed underneath to remove the crud, so it could twist back and forth to slide it out. WD40 will just lube what is there, not remove any grime.
To Tricks to pulling rear ABS Sensor?
