94 Rear Bearing Help Needed
Apr 16, 2005 | 08:31 PM
St. Jude Donor '05-'06-'07
Hi Folks,
I would like to try to replace the rear hub assy myself instead of paying $300 for the bearing and $100 labor.
My local Pep Girls has the hub for $169. Sears has the 36mm socket for $7 and I have a T55 3/8 drive. Do you all think these tools will do the trick?
Any and all suggestions are appeciated
Thanks in advance for your time,
Chris
Apr 16, 2005 | 08:41 PM
Apr 16, 2005 | 08:49 PM
If you have an Autozone near, you can borrow a 36mm socket from them. Also you will need a torque wrench to torque things properly.
Apr 16, 2005 | 10:31 PM
You may need an extension for the socket. I used a small piece of pipe that I placed over the ratchet handle to help break the 55.
Apr 17, 2005 | 08:40 AM
Quote:
Originally Posted by *89x2*
Thanks for all the help.
*89x2*, I'm sorry I missed the get together. It sure looks like everyone had a good time.
Chris
Apr 17, 2005 | 09:43 AM
I did it 2 weeks ago. The hard part is the T55's.
Just have a bunch of extensions handy.....
Apr 17, 2005 | 01:48 PM
Thanks, I just noticed after I bought the socket and the bearing that my torque wrench on goes to 140 ft lbs
Apr 17, 2005 | 05:19 PM
From: ...tearing up the highways, one state at a time™®©
Chris
I believe they will be having it again next weekend (Sat?)
Check w/ Bluewasp - in that thread...
Apr 17, 2005 | 07:08 PM
i just replaced the hub on my 95. I pulled the 1/2 shaft out at the same time and replaced the U joints. With the 1/2 shaft out, those T55s werent too bad. The new hub ***. was $142 at Advance Auto. It was Federal Mongul brand. Made in USA. Total time invested was 7 hours. It wasnt too difficult.
Apr 17, 2005 | 08:12 PM
Rear Bearing
I did mine last year. Bought the bearing at AutoZone, it was a Timken. It took about three hours. One of the T55's was a bit difficult to get to, but a few extensions did the trick. I didn't take out the half shaft as some have suggested. That would probably make the t55's easier to get to.
Overall, not too difficult. You do need a torque wrench. I think the large nut is torqued to 160 or 165 ft lbs.
