Another ET best!!!
My first last week ended in a rocker stud being busted off and a bent pushrod. After fixing it I had another chance today.
................................Previous best w/ Superram
60ft..........1.564 ...........1.516 ......+.048
330ft.........4.574 ............4.555 .....+.019
1/8m.........7.126 ............7.122 .....+.004
1/8 mph.....97.91 ...........97.29 .....+.62
1000ft.......9.338 ...........9.352 .....-.014
1/4m.........11.207 ..........11.227 .....-.02
1/4mph.....123.10 ...........121.96 .....+1.14
Oh, I did change my intake to a jeb built-single plane intake & plennum and electric water pump. Shifting at 6000+ vs 5200 with Superram
I did spin on the line - so I think there is more to be had on the 60'.
Great runs.
If my D-36 is still alive his D-44 will be fine.
So the 60' went from 1.51 to 1.56 with the intake change, how did the other increments change if you don't mind ?
Mike
i am looking into getting some drag rims and tires for my 91.. what type of rims are you running and what sizes?
can you tell me what spacing you had to use for front and rear..
i think if get that type of traction ill have to go with some shorter gears..
Mike
Not really sure about the 60'. I spun a good bit. I think if I hook good I could cut a 1.54 or 1.55. I am extactic at how good it feels up top. I never thought I would be shifting an L98 at 6100.
My SR will be going upfor sale when I have a chance to clean it up.
Thanks for you IM back on the head gaskets. I found " Clearing throat" Head bolts on the driver side where half turn loose from 70LBS..
New gaskets are going in anyways.. What tires are you running and PSI?
I hope to hit those numbers some day
