Stall Converter Recommendations
Old Apr 18, 2005 | 02:34 AM
dan6712cc's Avatar
dan6712cc
Default Stall Converter Recommendations
My 94 has LT's, about to put in a hotcam and 1.6 rr's.. also it has 2.59 gears.. what rpm converter should I be looking at for a daily driver with no track time. 2600? Any brand of tranny cooler thats better than others?
Also how difficult is it to install a converter and cooler yourself? I have a kwiklift so that should help out
Old Apr 18, 2005 | 02:44 AM
redcorvettedave's Avatar
redcorvettedave
2600 no less
Old Apr 18, 2005 | 10:05 AM
C4Crazy787's Avatar
C4Crazy787
Default My install
I installed a 2800 stall, it’s great just cruzing around, acts like stock unless you snap her passed ¼ throttle... then she’ll spin up .
The worst part was the left side middle bell housing bolt, I had to fight that one .
Also be sure and install a new front transmission seal.
Driveshaft out, http://forums.corvetteforum.com/phot...C_beam-med.JPG
Missing transmission,
http://forums.corvetteforum.com/phot...ys_out-med.JPG
Transmission ready for new seals,
http://forums.corvetteforum.com/phot...dseals-med.JPG
FYI this transmission jack kicks a$$!!
http://www.harborfreight.com/cpi/cta...emnumber=39178
My transmission cooler is a Hayden #514, 3/4”x 7.5”x 12” tube and fin design.
I placed the cooler on the AC condenser up in front of the primary fan.
Pic,
http://forums.corvetteforum.com/phot...anscooler4.JPG
I ran the hoses out the right side of the upper radiator shroud thinking the return line was the top one, NOT… it’s the bottom on my '92, so I used a 20” stick of pre-flared and fitted 5/16th tubing, ran it up from the lower radiator cooler outlet and connected it to the cooler inlet hose.
Purchased a tubing bender for the job (always looking to new buy tools). Took some time and used coat hanger wire to get the bends just right.
Pic,
http://www.digitalcorvettes.com/phot...er_lines_3.JPG
Luckily, I was able to bend the transmission return tube up and attach the hose from the cooler. The main objective was to not have the tubing and hose rub on anything, but where it did I installed some black plastic wire loom.
Pic,
http://www.digitalcorvettes.com/phot...er_lines_2.JPG
http://www.digitalcorvettes.com/phot...ler_line_1.JPG
This job was a little more work than I had anticipated but it’s finished and looks good.
Old Apr 18, 2005 | 09:44 PM
dan6712cc's Avatar
dan6712cc
Thanks for the replies, did you mpg change much? Now if only a vendor would do a GP on a vigilante
Old Apr 19, 2005 | 11:27 AM
C4Crazy787's Avatar
C4Crazy787
No, but I've only checked my Hwy mileage. In retaining the lock-up feature of the converter Hwy mileage should not change.
Old Apr 19, 2005 | 01:43 PM
crheinish's Avatar
crheinish
Get a 2800 Vigilante and some 3.73s
Old Apr 19, 2005 | 07:34 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I would check with some converter/tranny experts about that tranny cooler...when I put my converter in I was specifically told there was NO need for a tranny cooler unless I was road racing the car...for street and drag strip they said it just wasn't neccessary for stalls up to 2800...
Old Apr 20, 2005 | 05:53 PM
C4Crazy787's Avatar
C4Crazy787
If you plan to visit the drag strip even once... I highly recommend a extra transmission cooler, its cheap insurance.
Old Apr 20, 2005 | 06:39 PM
redcorvettedave
Cheaper than a tranny rebuild!!!
To Stall Converter Recommendations
