climate control head unit
Old Apr 18, 2005 | 02:32 PM
LSUgoTIGER's Avatar
LSUgoTIGER
Default climate control head unit
will a climate control head unit that is listed for 94-96 corvettes be compatible as a replacement for a 93 corvette? my unit went out, and I found this controller on ebay but it's labeled for 94-96.
Adam
Old Apr 18, 2005 | 09:00 PM
QuikZilver's Avatar
QuikZilver
Lettering color is different. 94-96 lettering was white, yours is amber. When I had a 93, I had to special order it. I think the 92 will work as well. Good luck.
(See, C5 owners wave )
Old Apr 19, 2005 | 07:19 PM
HTRK-1's Avatar
HTRK-1
If you can get the 94 - 96 cheap, I wonder if you could remove the bezel and swap the white button's for the amber one's you have? Just a thought. Did you try cleaning the connections on your controller to see if that corrected your problem?
To climate control head unit
