I know idle voltage of .3 to .9 volts is considered as "0" by computer, but what about the other end (WOT). I know 4.6 is considered good in real readings, in theory 5v. is max. possible. Assuming throttle plates are wide open, what is considered min. WOT TPS voltage to have computer maximize injector output (signal) ???
4.0v Or greater is sufficient to signal the ECM of a WOT condition.
Yep. In fact, the Shop Manual for the 86 says anything higher than 4.5 will set a TPS High Voltage error code.
Never saw any reference to .3 to .9 being considered "0" by the computer. Where'd you get that?
I don't know what year you have, but for the 86, .54 (+/- .075) is considered to be within spec. That means anythinhg from .615 on the high end to .465 on the low end is okay.
Many find that setting it at the of the scale offers improved throttle response.
Your 94's TPS will likely not read over 4.0v when the throttle is pegged.
Doesn't matter. On LT1's, the PCM reads as little as 3.75v as 100% TPS. All the 4.6v and 5v talk is for L98's.
