Injector size, confused
Old Apr 19, 2005 | 12:33 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default Injector size, confused
I was on another forum and there is a company trying to sell real large injectors to guys/girls. 32-40+ lb/injectors. And useing there formulas with my motor, they are saying I need 37# injectors at 42 psi with a brake specific fuel consumption of .5(I guess this is a standard number used for NA cars). Well my TTS datamaster shows my duty cycle is around 85%, 5 % higher than they recomend, at WOT with 30# SVO injectors at 42 psi.
Heres a link to a calculator that says about the same thing, estimateing me at 520 fwhp.
What do you guys think?
http://www.rbracing-rsr.com/fuelinjectors.htm
http://www.rceng.com/technical.htm
Old Apr 19, 2005 | 12:36 PM
Timmy!'s Avatar
Timmy!
I think you are fine with the 30# injectors. Jesse proved that you don't need the big # injectors unless you are WOT all the time, like a road course or something. I still run the stock 24# ones in my 383 but I am always above 5,000' in elevation and my injectors only run 90% at 5,500 rpm and above.
Old Apr 19, 2005 | 01:48 PM
crheinish's Avatar
crheinish
I think 30s would cover it. Talk to your tuner.
Old Apr 19, 2005 | 06:35 PM
steve40th's Avatar
steve40th
I agree, but the info being put out is like cams over there, bigger is better mentality.
To Injector size, confused
