Broken Bolt on Rear Shock Bracket
Old Apr 19, 2005 | 08:15 PM
Clay Assassin's Avatar
Clay Assassin
Default Broken Bolt on Rear Shock Bracket
One of the Two bolts holding the rear shock bracket on my 89 busted in half . What's next?
Get a drill and drill out the rest of the stud?
Sell the car?
Any suggestions?
Thanks,
Old Apr 19, 2005 | 11:15 PM
1985 Corvette's Avatar
1985 Corvette
Hmmm, well there are drill bits you can purchase which drill into the stud easy, however when it comes time to loosen to the left, the bit "bites" into the metal and acts as an extenstion of the stud. Check around, that's the only thing that come to mind now.
Old Apr 20, 2005 | 01:06 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Is there anything left sticking out? visegrips and heat (torch)
Is it flush? easyout.
Old Apr 20, 2005 | 06:39 AM
Clay Assassin
Yes, completelt flush, and no access from the back.
I have drilled out studs before with counterclockwise drill bits.
Just was hoping somebody had an answer.
Didn't look like you could stick a torch on it. The fiberglass wheel well is close on the other side.
To Broken Bolt on Rear Shock Bracket
