WHY DID GM put restrictive blocks in plenum???
Old Apr 21, 2005 | 09:32 PM
smacko's Avatar
smacko
Default WHY DID GM put restrictive blocks in plenum???
http://forums.corvetteforum.com/pho.../cat/500/page/1
'For some reason GM put restrictive "blocks" in front of the EGR passages and to the left and right of the throttle body openings. You can grind down the front blocks and you can radius the side areas for improved airflow'
I'm after a DEFINATIVE answer here guys'n'gals...It doesn't look like this was merely a machining ommission, so does anyone know WHY they deliberately put the 'ledges' in the floor behind TB?
Obviously it helps suck the EGR gases into engine better, so when one grinds out these ledges, does that mean EGR gas burging suffers?
I don't have a copy of TPI Hints so am unsure of any reasons they give...
Old Apr 21, 2005 | 09:37 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
the story i heard many years ago was, those humps were put in to prevent vapor lock while gm was testing in the desert heat. i don't know if many of us drive too much in the desert, but i ground mine out years ago and doesn't seem to hurt emissions any.
Old Apr 21, 2005 | 09:44 PM
smacko's Avatar
smacko
Interesting, thanks. Personally tho, I can't see how it would cause vapor lock given the Throttle body only induces air, not fuel mix.
Old Apr 25, 2005 | 09:33 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
They create a low pressure area directly above the EGR ports.
The airflow over them adheres to Bernoulli's Principle, speeding up as it crosses the restrictions thereby augmenting the pressure that provides the motive force for EGR injection.
Old Apr 25, 2005 | 09:53 PM
smacko's Avatar
smacko
That's what I was thinking all along (Tho I didn't know the name of the principal) - I showed my plenum to a mate who's a fitter and turned on the weekend; he still thinks it's likely that it was just the way it was cast and too expensive for GM to bother trimming
To WHY DID GM put restrictive blocks in plenum???
