TPIS Cam ?
Old Apr 22, 2005 | 08:52 PM
pipe's Avatar
pipe
Default TPIS Cam ?
I bought the TPIS Cam #700-701 solid roller off of a friend brand new with lifters but the dumbazz lost the cam card. Does anyone know what is the Intake lobe center. THANKS I MIGHT TRY PUTTING THIS IN ENGINE MODS AS I KNOW CORKVETTE HAD ONE IN HIS OLD 406
Old Apr 22, 2005 | 11:47 PM
500hp's Avatar
500hp
I have this same cam in my LT4 headed '92. TPIS will grind these cams to your specs, but this 700-701 is usually ground as follows; 242/242 duration @ .050", LSA 112 deg., Intake CL 108 deg ATDC, Exhaust CL 116 deg BTDC. Mine ended up with almost 244 deg of duration @ .050". Lift is .572" with 1.5 rockers or .609" with 1.6s (I run 1.6s). The recommended lash is .016" for intakes, .018" for exhausts. Advertised duration is 278/278. I just shoved it in my 350 and it screamed (think it may have been retarded a couple degrees), but I will be degreeing/checking it when I put it in my 383.
Old Apr 23, 2005 | 12:13 AM
pipe's Avatar
pipe
500hp thnks so much for the info
To TPIS Cam ?
