noise after engine is shut off
Old Apr 23, 2005 | 08:47 AM
ls5454's Avatar
ls5454
Default noise after engine is shut off
90 L98 6spd conv
I hear a rattle or something every time I shut it off, for about a second or so after the regular engine noises quit, which is nearly instantaneous. It sounds like it's from the right side of the engine bay, and it's independent of whether the clutch peddle is in or out or the A/C is on or not. I imagine it's something rotating that is finally coming to a stop. I suspect a pulley driven accessory, but what?
Any ideas?
Old Apr 26, 2005 | 04:44 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Check your harmonic damper and make sure it hasn't seperated from the hub.
Mine did and it made a noise like you have described.
Old Apr 26, 2005 | 04:50 PM
BLUE BETTY's Avatar
BLUE BETTY
could be the belt tensioner
john
Old Apr 26, 2005 | 04:56 PM
86C4EVER's Avatar
86C4EVER
Was the noise always there?
Some 6 sp. make noise at shut down.
Fred
Old Apr 26, 2005 | 05:20 PM
rws.1's Avatar
rws.1
Is your car fuel injected or carbeurated?
If carbed... you may have "dieseling" aka "run-on"
Dieseling
A condition in which gasoline continues to fire after the ignition has been shut off. In late-model engines, dieseling , or run-on, is caused by heat and the unusually high manifold pressure that result from retarding the spark at idle. Check following possible causes.
1-Check exhaust emission system.
2-Wrong type spark plugs.
3-Excessive carbon in combustion chamber.
4-Poor quality fuel.
5-High engine idle speed.
Old Apr 26, 2005 | 07:24 PM
ls5454's Avatar
ls5454
Where's the damper? It's not the 'frisbee', is it? I'll try to check that and the tensioner.
I can't say whether it's always been that way.
It's TPI, and this is definitely not run-on. I'm familiar with that.
Thanks guys
To noise after engine is shut off
