Tachometer going CRAZY
Old Apr 24, 2005 | 01:59 AM
crkemppainen's Avatar
crkemppainen
Default Tachometer going CRAZY
Went out for a spirited drive tonight and at the top of second gear I started getting a really bad missing and surgung. I got out of the throttle and slowed down...when I went to get backup to speed, It kept surging and I noticed the tach jumping around like crazy!
Pulled codes, got code 41, 44, and72
code 41 is in there because of the ICM fiasco and I did't clear it
44 is the left O2 sensor is dead
but what is a code 72???
Old Apr 24, 2005 | 03:33 AM
korvette4u's Avatar
korvette4u
code 72 =gear select circuit fault
as for the tack, tach filter is failing,, these are non existant anymore, but if you like you can build one, or find a used one.
Old Apr 24, 2005 | 04:27 PM
crkemppainen
Well I tried to start it up toaday and it was DOA. how embarassing.
cleared the codes, tried again...no-go
checked the codes
code 41 -EST code
pulled ICM and took it to parts store for testing.... tests good.
what is that crap?
Old Apr 24, 2005 | 04:50 PM
crkemppainen
OK...so after the test, i reinstalled the ICM and cleared codes again. it runs now with no tach problems....
where is the plling my hair out smiley at??
Old Apr 24, 2005 | 04:59 PM
scorp508's Avatar
scorp508
It could also just be a bad connection at the tach filter causing the intermittent issue.
Old Apr 24, 2005 | 05:44 PM
bogus's Avatar
bogus
Uh, this is a 1993... so lets be sure the codes to description is right.
To Tachometer going CRAZY
