Headlamp bushings?
Old Apr 24, 2005 | 01:23 PM
C10 JDR's Avatar
C10 JDR
Default Headlamp bushings?
89 L98
When I turn the headlamps on, the right hand (passenger) headlamp operates normally, but the motor continues to run for about four seconds after it is in the "up" position. Turn 'em off and the headlamp goes down ok, but again the motor on this side continues to run.
If I disconnect the battery (lights off), on reconnection the motor runs for four seconds or so again. The light stays down as it should.
Is this the infamous bushing problem, or a relay, or what?
Old Apr 24, 2005 | 01:33 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Assuming 89's are the same as my 90s then I would guess that the bushings are shot.
I believe there is a tech tip for this problem. I used that and bought the bushings from Lowes for a lot less than the mail order guys. The bushings were 1/2 x .194 x 1/2 nylon. They are kinda tight but work fine. These are also available at Home Depot.
Edit: Here is my thread on the prob. There are a few good links to tips and part numbers. http://forums.corvetteforum.com/show...m_id=48&arch=1
Old Apr 24, 2005 | 01:57 PM
C10 JDR's Avatar
C10 JDR
Thanks Dale, your symptoms were similar to mine so I guess it is the bushings.
John
Old Apr 24, 2005 | 02:29 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
I just did it, easy job.
Old Apr 24, 2005 | 06:24 PM
C10 JDR's Avatar
C10 JDR
Oh Yeah!!!
Try getting stuff from Home Depot from 3500 miles away!!!
(Only kidding, I am turning some up from some duralumin stock )
Old Apr 28, 2005 | 08:46 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I fixed my 92's last summer using Home Depot bushings. The parts number is 596609. You'll need 3 packs of 2 each for a total of 6 to do both headlights.
The UPC code on the package is 30699 87278. Total cost locally was $2.07 plus tax. Much cheaper than Eckler's or MAD and mine have worked fine ever since. Good luck.
To Headlamp bushings?
