Techniques for bleeding clutch slave?
It was simple to use and bled the system of all air in less than 5 minutes. I'd highly recommend the investment.
After I pushed the cylinder all the way back, I blocked it in that position with a short piece of 2x2 that I had previously drilled two ¼ inch holes completely through at 2-3/4 inches on center. I had also drilled a third hole exactly between the first two holes only about a ¼ inch deep as a place to hold the piston rod. I used two ¼ inch by 2 -1/2 inch screws and nuts to hold the block of wood to the slave (don’t torque the nuts, just us enough pressure to bottom the piston in the back of the cylinder). This effectively held the piston in the back of the cylinder. This method keeps the slave cylinder volume at a minimum which creates less possibility of trapped air remaining in the cylinder after your done bleeding.
At this point I pointed the slave upward with the bleed screw at the top, attached a clear piece of tubing to the bleed screw so I could watch for air bubbles and put the other end of the tube in an empty Corona bottle. From there you bleed it like a set of brakes. While the peddle is traveling down open the screw. When the peddle hits bottom, close the screw, peddle up, repeat. Watch the level of fluid in the master cylinder as it’s only good for about three or four cycles then your sucking air.
When you’re satisfied that the air is out of the system, remove the block of wood from the slave slowly. You need to loosen the nuts a little and then add fluid to the master, loosen the nuts some more and then add more fluid. If you aren’t careful about this you will suck air into your perfectly bled system.
Next time I do this I will make my little 2x2 jig out of metal as the slave piston eventually split it like a wood splitter. Fortunately, I was done bleeding when this happened.
Hope this helps.
Chris
Thanks to all who helped with this!
Chuck
Hope this helps.
Chris
I did exactly the same thing, except I made my plate out of a scrap piece of sheet stock I had laying around. I had always used the service manual method previously and went through 3 slaves before I built the bleeder plate. I haven't had a bit of trouble with the slave since.
