Is there any diagram anywhere that can tell me where to hook up the Headlamp Opening Actuator Modules to?
Thanks for your help!
i know through the 90 model year, that module screwed to the forward side of the front drivers side wheel well panel. you should see two diagonal holes in that panel towards the bottom in a flat area. it mounts with two 6mm bolts ( 10mm socket).
Freakin OUCH! $170 for one?? Glad I "aquired" one from the local junkyard.
Just mount the module and plug those connectors to it, headlights should work after that.
Just an FYI... That module looks like the same one used in the 90-92 Firebirds.
The connectors will only fit one way, one has more pins than the other. Also, note that ecklers says 84-96 but this is NOT factory for 84-87. 84-87 used 3 relays to control the headlight motors.
If you follow those wires into the harness they actually run down the frame rail and go back to the batter and some inside the car for the light switch. I'd look on ebay before buying ecklers, they show up on there all the time. Just do a search for corvette module or corvette head light, and make sure you get the right year range, 84-87 88-90 91-96.
I hope I'm not confusing you, but I have looked at that top pic alot and it looks to me you have an aftermarket head light kit. By the pic it looks like the back of a standard headlight socket. If that is the case you would be wasting your money buying the control module. Your pics to me look nothing like my car with the headlights on or off.
headlights on
headlights off
