Knock Counts up, before I replace the sensor...
Old Apr 25, 2005 | 01:30 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Default Knock Counts up, before I replace the sensor...
Before I replace the sensor, what else should be checked? The lifters are relatively quite and there are no apparent exhaust leaks in the engine compartment.
Old Apr 25, 2005 | 02:21 PM
JAKE's Avatar
JAKE
I'd first check the ignition timing and be sure I didn't get a bad tank of gas at the last fill-up.
Jake
