Clutch Fluid?
Old Apr 25, 2005 | 01:41 PM
Perfusion's Avatar
Perfusion
Default Clutch Fluid?
My car just crossed the 50k mile mark last month, and I guess I'm getting to that stage in ownership where I start replacing parts/fluids/etc. "just because"... This weekend, I thought maybe I should do the clutch and brake fluids?
Would there be any real reason to do this? Basically, what I am wanting to avoid is this situation: 50k miles down the road, I go to do some maintenance. Turns out it's worse than the mechanic realized. He says, "Boy...this coulda been prevented had you only -"
That's what I don't want to hear. Any suggestions?
Old Apr 25, 2005 | 01:53 PM
Grace91's Avatar
Grace91
I just flushed mine a week or so ago. I am also at the 50K mark. I put Valvoline SynPower back in mine and it seems to be working fine. Some say you need to use the GM fill but others don’t. The bleed was a pita but I think it was worth it.
At 50k you should really consider replacing both the master and slave. The ZF Doc would recommend this also. I will probably replace both my master and slave next winter when I have more $$. The Old Lady just bled my bank account dry buying herself a new BMW but now I figure I’m set for all my future mods and new paint.
Old Apr 25, 2005 | 02:01 PM
STL94LT1's Avatar
STL94LT1
Valvoline SynPower.
Old Apr 25, 2005 | 02:17 PM
bogus's Avatar
bogus
don't replace the master/slave. I know, in a perfect world... but GM is having a huge problem with those that are on the shelf right now.
My hydraulics have a small leak... I don't want to upgrade to a larger leak... so I ain't buying a new one anytime soon.
Old Apr 25, 2005 | 02:20 PM
Grace91's Avatar
Grace91
Forgot about that.. All the more reason to wait.
Thanks for mentioning.
Old Apr 25, 2005 | 03:08 PM
rws.1's Avatar
rws.1
Valvoline Synpower DOT3 +DOT 4 for both clutch and brake systems
Higher boiling point and less tendency to absorb water
Old Apr 25, 2005 | 04:00 PM
Perfusion's Avatar
Perfusion
Thanks everybody...
Old Apr 25, 2005 | 09:46 PM
DukeDiablo's Avatar
DukeDiablo
For the time being...I've just been siphoning out the old fluid from the reservoir, then putting in new SynPower, followed with a long series of slow clutch action sitting on a level surface. This seems to get any residual air out of the system.
The first couple of weeks (times) the fluid quickly turned black after driving; however, now it stays really clean looking.
I realize this isn't the best replacement method, but it seems to be an easy swap for now.
I've also done a similar procedure on my brake fluid and power steering fluid. I use a 99 cent turkey baster.
Old Apr 25, 2005 | 09:56 PM
music_man's Avatar
music_man
From: Cicero, IN "Change is inevitable, except from vending machines"
Bogus - How can I tell if the new Raybestos Clutch & Slave Cylinders have the problem you're talking about? Is there data code or some way to tell. I bought a new one sometime back and have not installed it yet.
Old Apr 26, 2005 | 12:17 AM
bogus's Avatar
bogus
No, these are GM parts only. I don't know if the aftermarket has this problem.
To Clutch Fluid?
