underhood wire harness install.
Old Apr 25, 2005 | 10:52 PM
sniperdiver37's Avatar
sniperdiver37
Default underhood wire harness install.
88 auto A/C and smog. How long how hard to replace underhood wiring harness?
I figure 15-20 min to get the old one out.
replacing with good used updated 88 harness. Anybody want to do it for me
Old Apr 25, 2005 | 11:24 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
try about 15-20 hours
Remember it goes all the way through the firewall, and to both sides behind the dash
Old Apr 26, 2005 | 06:03 AM
tommelton's Avatar
tommelton
Nope.
Which wiring harness underhood? The forward lighting harness or the engine harness? The C100 connector at the firewall separates using a 1/4" socket (I think that is the size - can verify if need be). The inside/dash harness and the underhood harness are three different components...all joined at the C100 connector behind the battery and brake booster.
I just replaced the underhood forward lighting harness and it was not a bad job.
Let me know which you need to replace.
-Tom
Old Apr 26, 2005 | 07:16 AM
LD85's Avatar
LD85
If it is seperated from the Alternator, Starter/ Dash info harness down by the battery, I would guess you could put it back in @ an hour if you can reach the injectors easily.
I seperated my alternator etc from the ECM harness and it makes it a lot easier.
Take your distributor out for easy access to ground wires etc.
Old Apr 26, 2005 | 08:39 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Originally Posted by tommelton
Nope.
-Tom
wow thanks for the correction. So there is a disconnect on the firewall that will allow you to remove the harness from the firewall out? I know the box is there, but I never really gave it much attention. I have a 89 in my garage with the motor out - so I will have to take a look at it and see what that will entail for a future project I am going to be working on.
Learn something new everyday
I am sure getting at it with the motor in the car will be fun, but with the removal of the distributer, it shouldn't be too bad.
Old Apr 26, 2005 | 09:04 AM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
i must be missing something. when i had my 89 down and tried to pull the harness out, it went through the firewall, but did not come apart at that bulhead connector. the only thing i could see that bulkhead piece doing was to provide a seal for the harness going through the firewall. my 86 that i am parting out is the same way.
Old Apr 26, 2005 | 09:19 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
That is what I figured that was there, but by the sounds of the guys above, maybe it is a connector.
Old Apr 26, 2005 | 09:39 AM
cv67's Avatar
cv67
St. Jude Donor '05
The harness at the firewall (pass side) can't be separated as far as I know. Wish it could, though. Think they were referring to just the forward lamp harness on the drivers side.
Old Apr 26, 2005 | 10:06 AM
hz900's Avatar
hz900
This is 100% correct. I can assure you. I just pulled mine a couple months ago and last week put it back in. I was replacing the harness so out of curiousity and to make sure I got all that I needed I tore that seal apart(pass side). The wires go straight through to the dash wiring harness.
If you have the engine out (like I did) it takes about 15-20 minutes. I have no idea with it in but I would think you'd atleast have to pull the distributor because the harness runs in between the block and the firewall.
Old Apr 26, 2005 | 10:27 AM
Sleazy Rider
on the 90' they started doing this. disconnect 5 wires and 2 vacuum fittings, and the harness pulls out. should have done that from the beginning.
To underhood wire harness install.
