newbie needs help
Old Apr 28, 2005 | 06:45 PM
Gonzilla's Avatar
Gonzilla
6th Gear
Default newbie needs help
I have recently bought a 96 collectors edition and want to add some power and speed. Whats the easiest upgrades to enhance performance? Also, I have a bit of shaking on the steering wheel while driving. Had breaks done before I bought her. Not real bad just that I worry...
Old Apr 28, 2005 | 08:11 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
With the manual trans. and it's ridiculously high overdrive ratio in 6th gear, you can add some gear to the rear with no real penalty in mileage. In fact around town, I could even see it helping, as well as adding to clutch life. Also a set of long tube headers and possibly upgraded exhaust (if you don't mind a little more noise) would pick it up.
Old Apr 28, 2005 | 08:45 PM
Gonzilla's Avatar
Gonzilla
6th Gear
its an automatic. what type of exhaust works well?
Old Apr 28, 2005 | 09:22 PM
MikeC4's Avatar
MikeC4
See Nathon Plemons wright up on performance enhancements that work and those that are BS. Look under "Basics" for "Performance Mods"
http://www.wku.edu/~nathan.plemons/h...rformance.html
Old Apr 28, 2005 | 09:43 PM
Corvette Kid
Brain fart on my part. I forgot that all CEs are NOT LT4s. Most of your quality aftermarket exhaust systems will provide some benefit. Generally, the larger and more free flowing, the better. How much noise can you stand? The headers will help a bunch, even with a stock system. Since you have an LT1, I'd recommend 1.6 roller rockers too. They and some upgraded springs can be installed in a few hours and will give a boost you can feel, increasing valve lift nearly .030" if I remember right. I'd recommend the B&M Shift Plus too. It accomplishes the same thing as a shift kit on an electronic trans., making your shifts quicker by increasing shift pressure via the PCM. Easy to wire in and install and is adjustable to your preference. Also reduces trans. heat by reducing slippage and prolongs trans. life. I also use B&M synthetic Trick Shift fluid. Beyond this, it'd be time for the more serious mods, cam, head porting, etc.
Oh, if you already have the 3.07 gear, don't worry about anymore unless you don't care about mileage at all. These are a great all around gear for the automatics. A higher stall converter would be of much more benefit for a daily driver.
Old Apr 29, 2005 | 03:24 PM
Gonzilla's Avatar
Gonzilla
6th Gear
Thanks fro the great advice
To newbie needs help
